Audio issue
  • Free48
    • Jun 2014
    • 119
    • Montana
    • 2019 SANTE 230 2017 SANTE 210 2011 SANTE 210 1991 454 BFN 1989 SN 2001 Ski Ray inboa
    Audio issue
    Maybe someone that is audio inclined could offer some advice…
    I recently purchased a 2011 SANTE and while garage boating I noticed that whenever the head unit (I think that’s what it’s called – I call it a stereo) is powered on, static can be heard through the speakers. Could this simply be that the settings are incorrect on the amps or head unit? And if so does anyone know what the factory settings were? Components include a Clarion head unit, a Polk Audio PA500.4 amp, a Polk Audio PA250.2 amp, Rockford tower speakers, and Polk Audio interior speakers. All of which I believe are factory original. Click image for larger version
ID:	486992 Click image for larger version
ID:	486993 Click image for larger version
ID:	486994 Click image for larger version
  • MLA
    • Dec 2009
    • 1312
    • Lake Wylie NC Area
    Is the static consistent through other modes like USB, CD, SAT or AUX?
    • Free48
      • Jun 2014
      • 119
      • Montana
      MLA, yes it is consistent through all the modes to include USB, CD, SAT, AUX, and radio.
      • brettmcox
        • Jan 2007
        • 284
        • Unknown
        I would guess that ground issues or low power issue. Odds are all speakers are running from an amp.
        One easy test... turn on the system, and get a rca to 3.5 plug, plug the 3.5 into your phone, and test each rca input on the amps.
        2001 Super Sport - GT40 1986 SN2001 - 351 1973 Cobalt - 188/888 2014 F150 Screw 3.5 twin turbo 2011 Expy 2002 F150 SCrew 2001 F150 SCrew 1973 K5 (toy) 1995 Burb 3/4 454 1991 K5 Blazer (DD/Toy) 1987 Honda Accord 1978 Ford F100 1981 Merc Capri 1991 Honda Civic 2002 Ninja 500R sold...
        • Free48
          • Jun 2014
          • 119
          • Montana
          Thanks brettmcox, I'll pick up a cable and try that tomorrow.
          • nautiques4life
            • Jan 2009
            • 696
            • SoCal
            Anyone ever heard of cutting the stereo ground at fuse panel? I seem to recall a conversation a long time ago specific to nautiques about cutting a ground on the driver's side fixing someone's noise... Im not a stereohead fyi
            • brettmcox
              • Jan 2007
              • 284
              • Unknown
              That would mean.... that the ground is lacking at dash with all the extas. The easy fix is to pull the ground from head until and add a new wire to battery...
              • MLA
                • Dec 2009
                • 1312
                I would wager that the bow speaker are driven off the head-unit. if they have static same as the rest of the system, then its generated by the head-unit and not likely a ground loop issue.
                • Free48
                  • Jun 2014
                  • 119
                  • Montana
                  Appreciate all the comments. I've located an expert and will have him take a look and report back. Hopefully it's an easy fix.
                  • chopp
                    • Nov 2014
                    • 68
                    interested to see what you find. i have the exact same issue with mine but they are xm9's on the tower.It sounds like just the tower speakers doing it in mine(they run off a seperate amp) but will have to get closer to the other speakers to see if there is any noise there too.
                    • Free48
                      • Jun 2014
                      • 119
                      • Montana
                      Chopp following your response I had to check - the static is primarily coming from my tower speakers however there is static coming from every speaker. I'll let you know what I find.
                      • chopp
                        • Nov 2014
                        • 68
                        ok let me know. I too double checked it out in the garage and found the same thing.Mostly coming from tower speakers but there is still some coming from the other speakers. It was also noticeable quieter static with the engine off compared to out on the water when the engines running.
                        • frankie
                          • Aug 2015
                          • 34
                          • New York
                          • 2014 Super Air Nautique 210
                          Free48. How did you make out with the noise issue. My 2014 210 has the same problem.
                          Current:
                          2014 SAN 210
                          Previous:
                          2003 SANTE 210
                          • Free48
                            • Jun 2014
                            • 119
                            • Montana
                            Thanks for asking frankie. I decided to forget about it for the summer and take it to a professional in the off season. To be continued...
