Best place to pick up a kick on wire?
  • Neverenough
    • Sep 2012
    • 907
    • Ft. Worth Texas
    • G
    I found a switched accessory wire under the helm to use as a power on wire for the WS420 and I think it may be causing some feed back or whinning noise. Should I run a wire over to the other kick on wires at amps and should I pick up the power and grounds over at amps as well?
    Thanks again for the guidance.
  • swatguy
    • 1631
    • Midwest/ Northern IL
    • 2008 SANTE 210
    Running them over to the same powersource and grounds as the amps is the best possible way to prevent interference. Same goes for the "remote turn on" , or in your description the /kick on wire.
    • MLA
      • Dec 2009
      • 1312
      • Lake Wylie NC Area
      Its rare for the turn-on circuit to induce noise, however, i'd redo it for another reason. You really need to have the EQ and amps turning on via the same source. Sounds like you are still using a traditional head unit for this. Thats what need to turn the amp and 420 on. If you are getting your EQ's B+ and B- from the helm, thats a good recipe for unwanted noise.
      • Neverenough
        • Sep 2012
        • 907
        • Ft. Worth Texas
        • G
        Awesome! Thanks for the help! Made the changes and hope to run it this week!
