Bluetooth question
  • DavidP
    • Mar 2016
    • 22
    • Novi, MI
    • 2011 SANTE 210
    Bluetooth question
    I have a 2011 SANTE 210 with Polk Audio and I believe a Clarion headunit. I would like to add bluetooth capability, or I should say that my kids are bugging me to add bluetooth. As the unit is intertwined with LINC, is there a simply and INEXPENSIVE way to add bluetooth? Stopped by a local shop but lets just say I left with little confidence.
  • Bevostein
    • Jun 2008
    • 521
    • Frisco, TX
    Buy one of these
    https://www.amazon.com/Bluetooth-Boa...le+rca+adapter
    Plug RCA into stereo AUX with an adapter if needed and wire the dongle to a 12v source or put a cigarette lighter male plug on the end
    • lucky7t
      • Mar 2011
      • 1306
      • Oklahoma
      • 2015 SANTE
      My old boat we installed the Wetsounds Bluetooth and worked great
      Current Correct Craft Boat
      Correct Craft Boats Owned
      • Evening Shade
        • Apr 2015
        • 1295
        JL Audio MBT-RX is relatively cheap Bluetooth unit ($40-50). In fact, I'm having one installed on my 2011 210 as I type this.
        • Jordan98
          • Feb 2016
          • 16
          • North Carolina
          • 2015 G21 409
          This may help out seen it on a couple of boats dont know how it will interact with the linc system tho but looks like a solid option. http://www.jlaudio.com/mbt-rx-marine...receiver-91126
          • DavidP
            • Mar 2016
            • 22
            • Novi, MI
            • 2011 SANTE 210
            The JL Audio product looks perfect for our needs. Is the install tough?
            • Soundman22
              • Jun 2012
              • 7
              • Indiana
              • 2013 Super Air Nautique 230 TE 2001 Ski Nautique
              David, if you can strip wire you can add the MBT-RX. For my boat I connected the red wire of the MBT to the blue amp turn on wire off the Clarion head unit, that way when the radio turns on it fires up the module. When the radio isn't on, the MBT doesn't need to be on. Tie in the grounds together and voila. Plug the RCAs into the AUX input. You'll lose the AUX that you have today, but who cares......now you have Bluetooth. You won't be able to track forward and back from the LINC, but you can from your phone.
              • swatguy
                • 1628
                • Midwest/ Northern IL
                • 2008 SANTE 210
                I run the MBT RX install is about 2 minutes. The clarity and range is awesome. It's the most cost effective solution for sure. You will lose the use of your remotes /screen regarding skipping songs and changing playlists( will have to do that on the device), but the volume will still be controlled through that.
                • DavidP
                  • Mar 2016
                  • 22
                  • Novi, MI
                  • 2011 SANTE 210
                  Thanks guys. The MBT-RX arrived today and my son plans to install in the morning. Obviously the easy part is plugging into the AUX but I am a little unsure about how you power it. Did the unit come with pretty clear installation instructions?
                  • Soundman22
                    • Jun 2012
                    • 7
                    • Indiana
                    DavidP See my post above for wiring instructions.
