Subwoofer for 210
  • David Analog
    • Sep 2013
    • 263
    • Dallas
    Originally posted by cedarcreek216 View Post
    I'm going to have to disagree David. The enclosure will be designed, chambers and all, for the specific sub just as it would be if it was going into the enclosure. It's just being located in a different place that has plenty of volume for the 10" sub. I'm confused how you can say SQ is in question in an application like this when the first air the sound will hit is actually inside the cabin instead of a second chamber like the compartment under the passenger seat, then the vent into the cabin. Seems SQ would be much better and much more accurate.
    You asked for thoughts. Looks like you are set. I'll let it go at that.
    • cedarcreek216
      • Oct 2009
      • 1009
      • Dallas, TX
      • 2018 210 2013 210 2009 216V
      I'm just trying to understand. Your boys at Earmark and Tim at Scream Marine both said this was the best location. Trying to understand how SQ will be comprised by putting it under the steering wheel if it's a properly designed enclosure. Your reasoning did not make sense to me, that's all. If I can get more vent area and not compromise the enclosure I'm curious as to how the SQ will be compromised.
      • David Analog
        • Sep 2013
        • 263
        • Dallas
        Okay. No doubt the starboard compartment location is an option if you want more output than a single IB 10-inch can provide, which is limited. But it doesn't solve all the issues associated with an enclosure inside an enclosure. It's not direct-radiating by any standard because both the woofer and the port cannot be connected in an airtight manner to a vent opening that is extended outward. So in no way will this nullify the impact of the helm console and adjoining cavities. Yes, you can get a bit more vent area on the starboard side but the port side allows for venting close to the sole. So the real advantage to the starboard side is that you are not losing storage space. Either way, whether the port or starboard side, will have all the same tactile bass tendencies with loss of tonal construction and transient response. The bass will be defined by the same percussive terms that apply to every woofer that is loaded in this manner. A bass-reflex enclosure can compound the issue. The type of woofer can compound the issue. There are many more elements than just the aperture. If you want me to elaborate then PM me. If you listen to nothing but rap with synthetic bass and drums, then don't worry about it.
        • cedarcreek216
          • Oct 2009
          • 1009
          • Dallas, TX
          Thanks David, we listen to everything but instrumental basically. I will PM you as I am still confused. It seems to me that both options are a ported enclosure inside another enclosure, weather it's the storage compartment or the helm. The way cheaper option is the starboard storage, so if it's not only more cost effective but also the best sound option then I need to consider it. I thought hands the helm option would be the best for sound quality but I'm no expert by far.
          • David Analog
            • Sep 2013
            • 263
            • Dallas
            Good. I look forward to that exchange. There's so much more to consider in this case than just the port versus starboard side.
            • markj
              • 1194
              • NorCal
              #21
              Hey! Wait a minute! I'd like to learn too!!! Why go off thread? This is interesting stuff here! Isn't that what forums are for?
              • lucky7t
                • Mar 2011
                • 1306
                • Oklahoma
                • 2015 SANTE
                #22
                Yeah David put more info here for the readers .
                Current Correct Craft Boat
                Correct Craft Boats Owned
                • David Analog
                  • Sep 2013
                  • 263
                  • Dallas
                  #23
                  markj and lucky7t,
                  Then ask me specific questions and I'll be glad to answer.
                  • cedarcreek216
                    • Oct 2009
                    • 1009
                    • Dallas, TX
                    #24
                    markj and lucky7t,
                    David,
                    I have not pulled the trigger on this sub set up yet, but it's going in Friday to get something done, just not sure what yet. Would you have any concerns with the vibration created with putting the sub under the helm? I know The Malibu dealer in town puts all their subs here, but should I be concerned with the LINC or any other electronics suffering from the constant vibration?
                    • MLA
                      • Dec 2009
                      • 1312
                      • Lake Wylie NC Area
                      #25
                      Thats actually been the factory spot for Malibu for about 12 models years, same with Tige. Centurion, Moomba, Supra and Supreme all place their OEM woofer under the helm.
                      • cedarcreek216
                        • Oct 2009
                        • 1009
                        • Dallas, TX
                        #26
                        I did not think I need to be concerned, but just wanted to throw the question out there.
                        MLA, I have done, or seen a ported enclosure in the void under the helm on a 210 like I'm talking about? It's a decent amount of cash for just a sub and want to make sure I don't make a mistake.
                        • David Analog
                          • Sep 2013
                          • 263
                          • Dallas
                          #27
                          There's no comparison between a Malibu helm and a 210 helm. The Malibu is open wide open and the subwoofer can be direct-radiating into the cockpit.
                          There are many concerns other than the vibration if you are trying to do better than an indiscriminate jackhammer.
                          What compromises are going to be made in order to insert a large bass-reflex sub enclosure from the bow side into that space, an enclosure that normally should be at least 1.75 cu.ft. exterior? Box made smaller? Port made smaller?
                          Just the tip of the iceberg.
                          • cedarcreek216
                            • Oct 2009
                            • 1009
                            • Dallas, TX
                            #28
                            So would I be better off donating some leg room in the open area under the steering wheel instead of cramming it in the void space? I'm just not ready to give up my clam shell storage as that's precious on the 210.
                            • David Analog
                              • Sep 2013
                              • 263
                              • Dallas
                              #29
                              I wasn't aware that you would have adequate depth out front of the driver's helm console. However, if so, that is by far your best SQ avenue, especially if the sub(s) would be mounted a bit low and angled downward a bit into a little open space below. If you have the available depth, this could be done with some loss of legroom but without any loss of foot room depth.
                              With the JL Audio 10W6 subwoofer you could run two 10" subs sealed in acoustic suspension (optimized in net 0.5 cu.ft. per) in a smaller enclosure than a single 10" bass reflex. Double the surface area, smaller enclosure, and far more of a precision bass driver. Nothing sounds cleaner than more sub driver surface area not having to create as much excursion to produce the same output.
                              Direct radiation, versus concealed in a compartment, means a more linear response, no loss of output consumed by the compartment, faster with no phase delay, a far more seamless integration with the cockpit coaxial satellites and better midbass articulation, and more.....'IF' it will fit and is made to look good.
                              • cedarcreek216
                                • Oct 2009
                                • 1009
                                • Dallas, TX
                                #30
                                I know it's next to impossible to determine anything from a photo, not know measurements, but here is a photo of the area under the steering wheel. I'm 6'-2" and my legs fully extended barely touch the angled wall in front of the drain.
                                My though would be to do a sealed enclosure and have the bottom of the box bridge the depressed area for the drain which would give me foot space like you mentioned. You think there's enough room there?
