Hey guys. Ok, just bought a new Pioneer stereo to install in my 93 S.N. anyway, the head unit has two power wires the "red" which I know goes to the Accessory switch of ignition (or to an accessory fuse on the dash) and there is a "Yellow" wire that says provides a constant 12v to the unit. My question is do you guys connect the constant power wire, or just forget it? I don't want extra drain on my battery, when the boat isn't in use, but I know also that I lose any saved "memory" settings if I don't have the constant power connected. Any thoughts, pluses or minuses on connecting or not connecting it??
Originally posted by flyweed View Postthere is a "Yellow" wire that says provides a constant 12v to the unit. My question is do you guys connect the constant power wire, or just forget it?
You will need to choose between MEM and a small power drain when the boat is not in use. Just note though, battery memory is not going to be a concern until month 5 or 6 of no use.
