Hi,
I have a problem of engine noise since few days on my 230, it appeared without particular reasons... So I searched the internet to find the solution and I find this guide : http://knowledge.sonicelectronix.com...-engine-noise/
I follow the steps give by sonicelectronix and, apparently, my problem come from my head unit ground (a Clarion CMD6, before it's was a CMD5 but the previous owner change it himself). So I check the HU ground connection and he's only connected to my amp by a little wire... I suppose it's not the proper way to wire the HU ground and, maybe, it can be bad for my amp ??
In your opinion, what is the best solution to connect the HU ground (directly to the battery despite the distance ?) ? Or maybe there is a ground plate somewhere near the HU...
Thanks !
Thanks !
