Stereo remote wiring questions.
  • TFreeman
    • Sep 2016
    • 6
    • Georgia
    • 1983 SN2001. Full resto-mod. https://www.wakegarage.com/forums/topic/216-balls-deep-in-an-old-ski-nautique-83-2001/?tab=comments#comment-1329
    Hi everyone, this is my first post here on PN, I've done a fair amount of reading on here over the past few months, but decided to join to post this thread. I'm working on my 83 sn2001, I'm looking for a little info on the simple wiring of the wired kenwood remotes.
    Currently ive got a kenwood unit installed in the glovebox, an amp running 4 tower speakers and a sub, and 2 speakers running off the head unit. All of this is running on its own deep cycle battery, sparked by a switch. It works awesome for being anchored out and listening to tunes.
    Anyway i I ordered two remotes (without the lcd display), 1 will be goin near the throttle for the driver to control and one near the rear for control near the swim platform. I believe the wiring is straight forward and the two would essentially be spliced to the stereo control wire, a power, a ground and an illumination wire. The illumination wire is where I'm hung up.
    Since the the stereo system is totally separate from the rest of the boats wiring, I'm not 100% sure what my best option is for that wire. I don't have an on board charging system for the stereo, so I feel illuminating the 2 remotes the entire time the stereo is playing could be a waste of valuable power. On the other hand, if I attached the illumination in to the navigation lights, would the remote suck a lot of power off of my main battery or only "receive signal" to illuminate from that circuit?
    as a last resort I guess i could add in a stereo illumination switch and handle it that way.
    Thanks for for the help.
  • shag
    • 2217
    I would not think the illumination would draw enough to notice... it should be a very small LED or LCD display... Kenwood should have a splitter for your remotes... I know that Clarion does....
    • TFreeman
      • Sep 2016
      • 6
      • Georgia
      Thanks for the reply, these non-lcd remotes attach in to the blue/yellow rem wire in the stereo harness, the lcd remotes use the more advanced wiring, I guess because of the data it carries. I did not get those because of poor reviews on the quality. I may be wrong on my thoughts of the wiring, but in my small amount of research, I think on the right track.
      The thought of them being an led light didn't even cross my mind for some reason, in that case, I think you are totally right on the low draw.
      Appreciate it.
