Stinger Isolator Setup,
  • itrynwake
    • Mar 2004
    • 32
    Was wondering if anyone has put in a stinger isolator SR200 specifically or SR80 ( i think ), was wondering... how the starter fit into the equation with the ignition wire.
    thanks
    04 SAN TE
  • Baken
    • 45
    • WA
    RE: Stinger Isolator Setup,
    I use the SR200... I tied it into the Ignition switch so when I turn the key over it closes the circuit and allows the battery to charge while the boat is running. you can hear the relay close/open when you turn the key. Hope this helps!
    • Roddbod
      • Sep 2004
      • 116
      Im glad i stumbled across this topic. I too am going to be installing an isolator and have the same question as itrynwake. The 04 team does not have a keyed ignition. How wouyld you connect this to the push bottom starting system. I too have an 04 but mine is an LE with the push start.
      • MHayes
        • Aug 2004
        • 830
        • Roswell, GA
        I'm in the process of installing an SR200, and was going to use as the true ignition source the yellow/red wire that runs to the starter. If you look in your manual, in the engine maintenance chapter, you will find a listing of the wire colors and what they represent. On a 2001 Air, which is our boat, the manual shows the yellow/red as the ignition start wire. Check your manual and it should give you some guidance.
        2001 Air Nautique
        • Baken
          • 45
          • WA
          What Mhayes said... as long as you get the "true ignition" your good to go.
            • 2908
            The isolators result in a voltage drop to your amplifiers so we stopped using them. Relays work pretty well but they have a few issues as well. Now we are using the Yandina/West Marine combiners. If you are running a dedicated battery bank for stereo and accessories these work well without the need for other switching devices.
