Adding transom remote. Advice/ pics needed please
  • XBIGPUN66
    • Oct 2012
    • 456
    • WI
    I am adding the round Polk transom remote on my 2014 210 and also the rectangular dash remote on my dash. I am asking for people to please post photos showing placement of their transom remotes and dash remotes for similar years 210's. I have seen them mounted in the walk thru and also on the rear part of transom on port side. The dash ones i have seen just to the left of the steering wheel. I would like to decide what is the best location prior to cutting the holes. Thanks.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Ian S
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    Measure 50x and drill a pilot hole with a tiny tiny bit before you go with the big 2" hole bit (drill in reverse with those big aggressive teeth).
    i measured 20x and was still surprised where it came through.
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
    • XBIGPUN66
      • Oct 2012
      • 456
      • WI
      Nyryan, do you have any pics of yours?
      Ian S
      • Guntersville230
        • Aug 2015
        • 419
        • Guntersville, AL
        • 2015 SAN 230
        Like the location cause if in the water you can still reach it as opposed to the walk though....just a thought!
        Sent from my SM-G935V using PLT Nautique mobile app
        • swatguy
          • 1631
          • Midwest/ Northern IL
          • 2008 SANTE 210
          As mentioned by Gunters, mounting it off to the side gives you access from the water . As much as they say remotes are waterproof , I always prefer to have them above or just below the rubrail.
          • XBIGPUN66
            • Oct 2012
            • 456
            • WI
            That looks like a good location on transom. Now I need to decide where to mount the dash one.
            Ian S
            • Guntersville230
              • Aug 2015
              • 419
              • Guntersville, AL
              • 2015 SAN 230
              Check out this helm location....
              https://www.planetnautique.com/vb5/f...remote-on-dash
              • XBIGPUN66
                • Oct 2012
                • 456
                • WI
                We are doing this project now. We realized when we got this started that the stereo already has a y-cable coming out of it which connects to the dash screen and the glove box head unit. Where do I connect the y-cable we will need to use for the two remotes?
                Ian S
                • Stevemo14
                  • Apr 2019
                  • 691
                  • Columbus, OH
                  You should be able to hookup your new Y cable to one of the ports on the existing Y cable. It might depend your your stereo though.
                  • XBIGPUN66
                    • Oct 2012
                    • 456
                    • WI
                    That will not affect the performance?
                    Ian S
                    • Stevemo14
                      • Apr 2019
                      • 691
                      • Columbus, OH
                      I wouldn't imagine. There should be no "performance" it should work, or not work. Its just sending signals to the head unit.
                      • XBIGPUN66
                        • Oct 2012
                        • 456
                        • WI
                        Right, just there is data being transferred to the various displays, etc...
                        Ian S
