Which breaker for sub amp?
  • ZachD
    • Mar 2014
    • 109
    • Columbus OH
    • 2014 G21
    I currently have an aftermarket 12in sub connected directly to one of the two batteries in my boat. That said, I want to connect it to the panel circuit breaker in ACCY spot so that I can switch which battery is powering it. I wanted to ask if anyone could help me know which amp breaker to purchase here for the setup I have. The amp is an MTX 421D and the specs are listed here. Candidly, I don't know much about this so any advice on what to do once I purchase the breaker is appreciated. I assume I can take the same wire that is currently directly connected to the battery and wire it into the breaker (what amp #) on the panel box...? thanks!
    I believe this is the only part I need : http://www.nautiqueparts.com/product...rs-pcm-engine/
    Specs of the amp I am hooking up here under DETAILS tab: https://www.crutchfield.com/S-9fksyl...under421D.html
  • swatguy
    • 1631
    • Midwest/ Northern IL
    • 2008 SANTE 210
    Just fake the positive right now going from your battery to your amp and run that to you perko switch main positive post instead of going to the battery......... .Viola
