7.7 JL-M Audio tower speakers on 2017 G23 - fade control issue
  • GMLIII
    • May 2013
    • 2795
    5 minutes ago
    I have a 2017 G23 with a set of 7.7 JL - M Audio tower speakers. I do not have the top of the line audio system that is an available option on the 2017 G23. Im trying to figuire out whether there is a fade control for the tower only speakers because in order for the wakeboarder being pulled behind the boat to hear the music from the tower speakers, I have to turn the audio volume very high hence blowing away the folks in the boat in order for wakeboarder to hear the music. There is a fade control for front and rear speakers but no fade control for just the tower speakers. If anyone else has had this issue or knows what I may be missing please let me know.. The speaker prep kit I ordered on the boat is a JL- M Series Elite pre-wired 4 channel amplifier with only 2 tower speakers and not 4 tower speakers
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    This really belongs on the Stereo/Lighting/Electronics page but I'll answer it here. It sounds like your G23 is setup a bit different than my 230. The fader on my stereo fades between the tower speakers and everything else. Not really "front/back" but it works.
    You have a couple of choices. You can redo the wiring setup so it fades like this or you can add in a Remote Level Control. It's this: https://www.amazon.com/JL-Audio-HD-R...eywords=hd-rlc
    It plugs into the amp and you mount it somewhere convenient. It then serves as a way to turn down the level of whatever channels on the amp you have it configured to control. All of this explained in the JL Amplifier Manual here: http://mediacdn.jlaudio.com/media/mf...pdf?1305758648
    -Charles
    • Tallredrider
      • Oct 2014
      • 1026
      • St. George, Utah
      GML,
      Something like Charles recommends is perfect. I have the Roswell volume control knob and think it is the best thing since sliced bread. If you want to have some subwoofer and EQ controls, then a Wetsounds 420 solves the same problem but is more elaborate. I am still mystified that the spot just above the driver's left knee was not made big enough for a unit like that. Here is what my knob looks like. I keep the volume on the head unit close to max, and then control it with the Roswell volume control knob. Or I put it in the middle, and use the speed related volume control, both methods work pretty good for me.
      https://roswellmarine.com/dualzonevo...rolfeature.php
      I thought for sure I had a picture of it installed, but I don't. I put it right here:
      For some reason, the site will not let me upload from URL.
      http://i243.photobucket.com/albums/f...psuoovm6dr.jpg
      • GMLIII
        • May 2013
        • 2795
        Thanks to both of you for the info. I think I will try the remote level control as Charles suggests
        • OKWAKEBDR
          • May 2005
          • 750
          • Lakefront
          • 2017 Super Air Nautique G23
          Installed the RLC on mine a few weeks ago. One for the tower speaker amp and one for the interior amp. Very easy to do. I ran the wire around the bow to the driver's seat dash.
          Current: 2017 G23
          • Tallredrider
            • Oct 2014
            • 1026
            • St. George, Utah
            Note that OKWakebdr put one for tower and one for interior. That is wise, IMHO. You are still stuck with using the touchscreen for volume control of the interior if you do just a line level controller for the tower speakers. And you won't be able to turn down the interior and turn up the tower speakers, you would just have both on or only the interior on. I often turn up the tower speakers and turn down the interior. I can still have a conversation in the boat, and my rider still jams out.
            So I would plan on 2 controllers, or the Roswell unit that has 2 controllers on the same knob. I just want to help you think it through all the way. With 2 controllers, you would have better control without having to toggle through the screen for volume controls, and full independent tower and interior controls.
            • lashburn
              • Apr 2016
              • 112
              • Oceanside
              • 2016 G21 Coastal H5
              my Boat is the same ......I fade louder to Tower speakers when we are Boarding so I don't blow the Boat out.
              I might get the RLC JL remote knob...easy fix, but where to mount and look nice...
              Polk sells a ZONE control module that require some additional work and harnesses...Also requires Dealer to turn on ZONE feature in your Touch Screen brain
              This is what the STUDIO Elite adds as well.
              from beyond 2014 X-46 2014 X-30 2013X-30 2006 X2
              • GMLIII
                • May 2013
                • 2795
                Thanks Tallredrider. You have sold me on purchasing 2 RLC JL remote knobs vs 1 now that you explained it to me in detail. The tough part will be hiding the wiring and where to mount knobs so knobs dont look like an afterthought.
                • lashburn
                  • Apr 2016
                  • 112
                  • Oceanside
                  Let me know where. I'm going to do the same thing
                  • Guntersville230
                    • Aug 2015
                    • 419
                    • Guntersville, AL
                    • 2015 SAN 230
                    Click image for larger version  Name:	volume control.jpg Views:	1 Size:	74.5 KB ID:	518001
                    This is a pic from Jeff's old G23 with the roswell zone control....Mine is mounted somewhat where the sub control knob is in this picture (under the start button) but a little further back and flush with the under helm fiberglass. Just some ideas....
                    • OKWAKEBDR
                      • May 2005
                      • 750
                      • Lakefront
                      Yeah, except for me, it's usually turning down the interior because one of my kids fell asleep with their head next to the speaker.
                      Current: 2017 G23
                      • GMLIII
                        • May 2013
                        • 2795
                        OKWAKEBDR if not too much trouble could you send me a picture of your RLC knobs install at your helm.
                        • OKWAKEBDR
                          • May 2005
                          • 750
                          • Lakefront
                          I responded to your DM. I'll get some pics this weekend.
                          Current: 2017 G23
                          • Kporsch
                            • May 2013
                            • 121
                            • Houston
                            • 2018 G23
                            Here's my RLC install (I'm pretty sure OKWAKEBDR copied me):
                            • Tallredrider
                              • Oct 2014
                              • 1026
                              • St. George, Utah
                              Here's what it the Roswell knob looks like on the left hand side. Depending on your personnel and need for control, you may or may not want the knob within reach of anyone besides the driver. With my personality and crew, the left is a better option.
                              Is anyone else having a hard time with photobucket these days? I keep getting an error code that it is the wrong file type.
