Currently I have (2) 7.7 JL-M Audio tower speakers on my 2017 G23. The speaker prep kit I ordered on the boat is a JL- M Series Elite pre-wired 4 channel amplifier. I was thinking off adding 2 more 7.7 JL-M Audio tower speakers. I was wondering if this speaker prep kit had the wiring within the tower to add the additional 2 speakers or whether the wiring for these additional speakers would have to be rewired through the tower. I opened the tower rubber stop holes for the additional speaker locations to see if I could see additional wiring for (2) more speakers but I did not run across any. Can anyone verify whether the additional wiring is already in place if I were to add 2 more speakers (speaker prep kit in place is called JL-M Series Elite)?
I did this last year with my 2016 g23 that only had two 8.8 from factory. When I pulled rubber plugs in tower, speaker wire was attached to them without a connector. I ordered matching connectors on amazon and installed speakers and plugged them in. Next , had to remove the panel board that held my amp. Behind it was the speakers wires that I just connected to new speakers. They had to be installed then in the amp. They work perfect, no issues.2016 G23
Originally posted by GMLIII
the wires were attached to the rubber plugs with a string. yes they sound good. twice as good.my amp is the bigger one made for 4 speakers.
2016 G23
Deutsch DT series 4 pin.... style terminals 16-20 awg
X000W2Q47F
Thats what the package said. Came with four connector ends (only used two because the new speakers had ends on them) and appropriate pins.2016 G23
Originally posted by Whitetail15 View PostDeutsch DT series 4 pin.... style terminals 16-20 awg
X000W2Q47F
