Official - 2018 Stereo is Backwards Compatible
  • scottb7
    • Aug 2011
    • 2198
    • Carson City, Nevada
    I have had 0 problems with the linc or the polk head unit....and those that know my posts know that i would be honest....
    i am not saying it is high or low quality...i have contemplated going directly from my phone to the amps to improve the quality a bit...i tested it and it would be better. and this can easily be accomplished by using a couple different options from wetsounds.
    however, you would lose ability to use linc to change volume and the autovolume feature...so i am sticking with it as is...
    • Waterhawg
      • Jan 2017
      • 61
      • Atlanta
      • 2017 G-23
      When will there be more information on this upgrade? I have heard it was definitely going to happen, has anyone done it? More information please.
      • distinguishedmotorsports
        • Aug 2016
        • 482
        • Austin, TX
        the MM100s has Hi voltage line outs so that may be a big plus over the polk.
        the wiring and software update is not out yet i imagine.
        you guys just need to buy the head unit and a remote. install it. take boat to dealer, have them update software and connect jumper to make mm100s talk to LINC, then you are good to go. the only reasons why you need wiring and software update is to have volume control on LINC screen.
        its really not that complex.
        • charlesml3
          • Jan 2008
          • 2454
          • Lake Gaston, NC
          • 2022 G23
          It's more than that. From the LINC screen you can select the input for the H.U. Also balance, fade, bass, treble, etc. You can also turn the H.U. on and off from the LINC. If you have SiriusXM, you can change stations from the LINC. IDK how much of that will have to change for the new unit, but all of that needs to work.
          -Charles
            • Aug 2016
            • 482
            • Austin, TX
            -Charles
            LINC behaves really similar to a remote. there's a remote connection on the back of the head unit. JL makes Y splitters so you can connect more than one remote. None of that has to change to the new unit because the new unit contains all of that already.
            • charlesml3
              • Jan 2008
              • 2454
              • Lake Gaston, NC
              • 2022 G23
              #21
              I understand that, but the LINC is not a "universal" remote. It needs to be programmed to talk to the new H.U. They're different manufacturers, even.
              • Tallredrider
                • Oct 2014
                • 1026
                • St. George, Utah
                #22
                Wouldn't the software update fix any problems with that?
                • charlesml3
                  • Jan 2008
                  • 2454
                  • Lake Gaston, NC
                  • 2022 G23
                  #23
                  Yep. And that's what we're waiting to see. Nautique said they were going to do it. Now it's a matter of if they'll really follow through on that.
                  -Charles
                  • wakerider107
                    • 271
                    • south
                    #24
                    Has there been any movement on this? I have not heard of a software update yet
                    2012 SANTE 230
                    • kylant
                      • May 2010
                      • 540
                      • Lake Tahoe
                      #25
                      mine is at the dealer getting this done right now
                      • wakerider107
                        • 271
                        • south
                        #26
                        They have a software update? The most recent updates for 2017 model year is 7/22/17 and 2016 model year is 10/12/16 - at least that I am able to find.
                        2012 SANTE 230
                        • kylant
                          • May 2010
                          • 540
                          • Lake Tahoe
                          #27
                          I'm not exactly sure. They are installing the JL head unit, bow speakers, amp, sub, and underwater lights. They are basically upgrading my stereo to the '18 upgraded model. they have to update the LINC for the underwater lights. They didn't say anything about not being able to update the LINC for the '18 JL unit.
                          There is another thread where the update has been successfully done.
                          • charlesml3
                            • Jan 2008
                            • 2454
                            • Lake Gaston, NC
                            • 2022 G23
                            #28
                            There should be no update to the LINC for underwater lights. It's just an on/off toggle in the Dealer's menu.
                            • kylant
                              • May 2010
                              • 540
                              • Lake Tahoe
                              #29
                              picked up my boat from the dealer yesterday. new JL head unit, amp, sub, bow speakers. everything works they way it should. boat now has zone control from LINC
                              2017 GS20
                              • etang789
                                • May 2009
                                • 155
                                • Hong Kong
                                • 2017 Super Air Nautique G23
                                #30
                                How much did they charge you for the JL Headunit and LINC programming?
                                2017 Super Air Nautique G23 Coastal Edition
                                Crusader H6 Coastal Direct Injection 6.2L
                                2010 Super Air Nautique 210TE Coastal Edition
                                Crusader 6.0L ZR-409
