Official - 2018 Stereo is Backwards Compatible
  • Schwiiing
    • Mar 2008
    • 129
    • Norris Lake, Tn.
    • 2017 SAN G23 H6
    #31
    So Nautique admitted that there is an issue with the Polk head unit in my 17 g23 and has been since new just 1 year ago. They said the only fix to the issue is to replace the head unit with the new JL unit. Nothing else they have tried has worked. Swapping the units out is the only fix..... but they will not cover the cost of the unit nor the install.
    *Nautique warrants to the original owner or user, that each new Nautique boat, as originally manufactured by Nautique, shall under normal authorized use be free of defect in material and workmanship for a period of five (5) years or 1,000 hours from the date of delivery (whichever comes first). This warranty applies to factory-installed components including boat parts, options or other components not manufactured by Nautique Boat Company and is transferable one-time only to the second owner.
    I call B.S. !!!
    • GMLIII
      • May 2013
      • 2792
      #32
      I call B.S. !!!
      • wakerider107
        • 271
        • south
        #33
        I call B.S. !!!
        Did you ever have any resolution to this?
        2012 SANTE 230
        • buzzardmountain
          • May 2004
          • 80
          • NC
          #34
          I have a 2016. What are my options for changing out the Polk head unit. My biggest issue is I’d like to bypass a “feature”. When my volume level hits #18 or #19 it just falls on its face. The unit cuts the bass out I’m assuming to protect speakers/subs. I’d very much love for this not to happen…
          • distinguishedmotorsports
            • Aug 2016
            • 481
            • Austin, TX
            #35
            you could do a JL media master and have the oem screen display everything if you get the retrofit kit from your dealer. or go down the aftermarket route with just about any multizone source unit and loose the factory display showing stereo info. up to you and your budget.
