rear speakers stopped working
  • hawleypa
    • Jul 2017
    • 4
    • USA
    • 2006
    I have a 2006 air Nautique with 6 speakers, recently the rear 4 stopped working. I have checked the wiring (as much as I can) and cannot find any loose connections. Would anyone have any ideas as to how I would fix this.
    Thank you
  • MLA
    • Dec 2009
    • 1312
    • Lake Wylie NC Area
    In that year model, it was common for the bow pair to be driven by the head unit and the main cabin 2 pair pair to be driven by a clarion 4 chnl amp. If there is an amp in the port, locker, is light up with its normal mode power light?
    • rlwagens
      • Feb 2008
      • 147
      • Michigan
      • 2006 SANTE 210
      What MLA said. If your system is still stock should be an amp running the cabin speakers and the 2 bow speakers are run off the headunit. Check for a green light on your amp, make sure red and white RCA cables are plugged in, and check fade/balance on the headunit.
      • hawleypa
        • Jul 2017
        • 4
        • USA
        • 2006
        Thank you, Im useless with electronics. If theres no light on the amp am I to assume it needs replacing. I already checked the wiring and the wires I can get to seem to be connected properly.
        • MLA
          • Dec 2009
          • 1312
          No light means the amp is not powering up. Could be bad amp, could also be loss of voltage on the main power cables or no turn-on trigger at the remote turn-on terminal. Next step would be testing things with a voltage meter
