Tower speakers/amp problem
  • SuperAirHokie
    • Apr 2015
    • 45
    • Lake Anna, VA
    • 2014 Super Air Nautique 210
    My 4 tower speakers are not working. Traced it to power amp. Had tech check and said amp getting power. Bought exact same stock Polk amp, which worked for a while and is out again. Tech checked again and says I have power to the amp.
    Any thoughts or suggestions? Anyone else have a similar problem.
    I only have one amp that runs all 4 tower speakers. Seems that cabin speakers are run off of base unit.
  • charlesml3
    • Jan 2008
    • 2453
    • Lake Gaston, NC
    • 2022 G23
    It's more than just the amp getting power. It has to also be getting a signal from the head unit. You need to check this. First thing to check would be the cables between the head unit and the amp. If that seems good, you'll need to figure out a way to test just the amp.
    -Charles
    • SuperAirHokie
      • Apr 2015
      • 45
      • Lake Anna, VA
      Power light on amp not on, so it seems to be a power issue. So the lines in have power, but the amp is off.
      • MLA
        • Dec 2009
        • 1312
        • Lake Wylie NC Area
        In that case, what about proper voltage on the turn-on circuit?
        • SuperAirHokie
          • Apr 2015
          • 45
          • Lake Anna, VA
          Tech confirmed that too. That's the blue wire I believe.
          • MLA
            • Dec 2009
            • 1312
            Ok, sounds like a 2nd dead amp. Now, the trick is to find the root cause of two dead amps in a short period of time in the same locations driving the same speakers.
            • SuperAirHokie
              • Apr 2015
              • 45
              • Lake Anna, VA
              Makes no sense. My brother is an electrician. Will get him under there next time. In the meantime, I guess I'll have to hum.
              • Flyindutchman
                • Sep 2016
                • 213
                • North Bay, Ontario
                • 2015 Super Air Nautique 210
                Well that is frustrating...
