Running Wire for Tower Speakers
  • MHayes
    • Aug 2004
    • 830
    • Roswell, GA
    Just curious if when running the wire for the tower speakers, has anyone drilled straight through the front of the tower (instead of drilling a bigger hole in the top of the flat bar) to get the wire from the round bar to the flat bar on top of the tower? The hole would be much smaller and you could just insert a small plug into it. Hopefully everyone understands what I'm talking about, if not, I can provide a picture.
    2001 Air Nautique
  • MHayes
    • Aug 2004
    • 830
    • Roswell, GA
    See red circle on the picture
    2001 Air Nautique
    • ckligor
      • May 2006
      • 12
      I'd bend a snake and run that down the line before drilling another hole
      • MHayes
        • Aug 2004
        • 830
        • Roswell, GA
        Ckligor, I think you misunderstood what I was asking. It's no problem to run the wire up to the top of the tower in the round bar, however, going from the round bar to the flat bar on top of the tower you need to drill a hole. The majority of the time, I have seen people take a holesaw and make a large enough hole in the flat bar (close to the round bar) in order to drill through the round bar on the inside to get the wire through. Once they have the wire into the flat bar, they put a plastic plug in the hole drilled by the holesaw. Instead of taking this approach, I was thinking of drilling through the front of the tower (i.e. the round bar) and straight into the flat bar, thus only having one small hole to plug up.
        2001 Air Nautique
        • ckligor
          • May 2006
          • 12
          My bad. I totaly misunderstood whay you where doing.
          • darrel409
            • Jul 2004
            • 566
            • San Dimas, So. Cal
            Do you really need to run thru the oval bar? My speakers hang off the rear round tube, but my speaker wire comes out the back of the front round tube ( just to the left, backside of your red circle) and plugs into the speaker on the rear tube.
            • YoungLifeSkiMission
              • May 2006
              • 70
              • Sydney,Australia
              Anyone got any pics of what they are talking about? Im in the middle of drilling and wiring tower speakers, i have drilled into the flat bar next to were the light wire comes out, then will run the wire up the flat bar and out (drilling on the side of the flat bar) and into the front round bar-not sue if that makes sense-ill post some pics.
              2006 210
              www.skimission.com.au
              • redelf75
                • Sep 2003
                • 767
                • NYC
                Mine are like what Darrel is explaining. Probably not the best installation, but acceptable for me. Especially as my bimini is always open
                • Mikeski
                  • 2908
                  • San Francisco, CA
                  Grant had to do this when he installed his tower flag, his solution will work for you if you must have the wires coming out of the rear bar. Mine are done like Redelf's too, IMO it's not worth the trouble to move them to the rear (probability of chaffing issues too).
