Read the owners manual carefully. You have to populate at least 50% of the RCA inputs, or 100% depending on how you configure the inputs. The reason you can't get the output voltage up to spec is because you do not have a symmetrical +/- signal when bridged. You're running a positraction differential with a 14" tire on the left and a 22" on the right side. Also, that has to sound like #&@%!
Originally posted by David Analog View PostHopefully you have temporarily disconnected the speakers while setting the gains with this method. Could be a problem getting the output voltage up to spec if you don't have adequate supply voltage to the amplifier (12.5 volt minimum), or without populating all amplifier RCA inputs, or having the input configuration wrong. JL Audio makes a 7 volt line driver, which should not be required to get full output voltage, but could improve the performance.Originally posted by MLA View PostNeed to read post #5 from David. He nails it as usual.2017 Super Air Nautique G23 Coastal Edition
Crusader H6 Coastal Direct Injection 6.2L
2010 Super Air Nautique 210TE Coastal Edition
Crusader 6.0L ZR-409
