I inquired about this with my local dealer twice and was blown off the first time and the second I was looked at rather strange for making such an inquiry. Any idea where I can find a capable dealer in Texas who's willing to work with me?
Curious..... some have had a successful swap to the new head unit with the new software and are saying everything is now working the way it should..... with the new software updated to match the 2018 software, would they now be able to have the steering assist added to the boat and have its full functionality?
- May 2010
- 538
- Lake Tahoe
- 2014 210 2019 GS22, 2017 GS20, 2000 Air Nautique
Originally posted by Schwiiing View PostCurious..... some have had a successful swap to the new head unit with the new software and are saying everything is now working the way it should..... with the new software updated to match the 2018 software, would they now be able to have the steering assist added to the boat and have its full functionality?
I bought the MM100 to retrofit onto my 2017 G and also picked up the retrofit kit from the dealer (minus the transom remote parts since I don't care to have one and it cut the cost down significantly). I've run into 1 problem and that is that my LINC screen to old Polk headunit used some kind of 4-pin JDAB connector and there's no way to connect the LINC to the JL unit. Does anyone know if there's a way to convert the JDAB 4-pin to N2k? Or is there a different wiring harness for the LINC to stub out an N2k port?
Separately the wiring harness has about a 20ft green/yellow pair stubbed out to power and a couple deutsch connectors which I have no idea what it's for but guessing I don't need it. It's clear the HU will have the appropriate power / amp turn on connections and RCAs for the zones, once the LINC is connected should be set and I will leave the long green/yellow wire disconnected.
Here's the harness off the back of my LINC showing the JDAB
And here's the n2k off the back of the JL headunit (came as part of the retrofit kit)
Turns out the yellow/green 20ft section actually gets run around the bow into the LINC screen. This provides the remote connectivity via the NMEA adapter into the headunit. My older version of the JL MM100s already has a deutsch connector CAN bus but it's male and I need to connect it to the male on the wiring harness so a little modification will be required. Nautique sent me the PDF installation guide if anyone needs it.
- Mar 2002
- 16457
- Lake Norman
- Mooresville, NC
This has been added to the Brochures & Manuals Section.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
