SD6 to rev3som?
  • G25 Bruiser
    • Sep 2017
    • 16
    • Seneca Lake, upstate new york
    • 2017 G25 xr7
    SD6 to rev3som?
    anyone have this set up? Wetsounds sd6 hooked up to the wetsounds Rev 3som?
  • MLA
    • Dec 2009
    • 1312
    • Lake Wylie NC Area
    Been running it for a few years now. Doesnt get much better then this. One amp does it all with only a single pair of RCA and cabling.
    • G25 Bruiser
      • Sep 2017
      • 16
      • 2017 G25 xr7
      This is good to know, I called wetsounds and they recommended not to run that much power to the rev 3som. That's running bridged 585 x 3. Seems to me the best combo, vs running 4 rev10s. Am I right? Or wrong?
      • MLA
        • Dec 2009
        • 1312
        "I called wetsounds and they recommended not to run that much power to the rev 3som."
        In the case of the rev-10, this would be a true statement. However, the amp is not all 585 or nothing. Tuned correctly, its perfect. In the case of the rev-410, 600W rms is PERFECT. Going further, you would likely not even unleash the full 600 to the 410 as you would want to gain match the 410 to the rev-10's and you likely reach that before peaking at the 600W rms.
        Sounds quality wise, if we can mount the 3-some, ill take it over 2 pair of rev-10. If we can mount two rev-410, ill take that over the 3-some.
        • G25 Bruiser
          • Sep 2017
          • 16
          • 2017 G25 xr7
          Is there anyone on here that can confirm if the rev 3som will fit on a 17 g25 tower?
          • MLA
            • Dec 2009
            • 1312
            it will take a fabricated bracket to mount the 410 in the center.
            • G25 Bruiser
              • Sep 2017
              • 16
              • 2017 G25 xr7
              I thought I read on here someone mounted a 410 using the swivel clamps? I believe it was on a 2015 g... he was having trouble mounting bc of the Bimini.
