Underwater Light Circuit Fault
  • blueroom
    • Mar 2017
    • 623
    • Northwest
    • G23
    Hi
    I am getting a Circuit Fault / Overcurrent error when turning my underwater lights on. It had happened previously when the engine was running, but now it happens with just the battery switch on and engine off when switching the lights on. Lights blink on briefly, LINC shows CIRCUIT FAULT and an overcurrent error shows in the the power diagnostic screen. Boat is a '16 G23.
    Thoughts?
  • Infinity
    • Sep 2017
    • 730
    • Lake Norman - Denver, NC
    • 2014 SV244 w/ ZR409
    I may be wrong, but was under impression that most of the underwater lights were "water cooled" and not supposed to be run out of the water. Could that be the issue?
    • blueroom
      • Mar 2017
      • 623
      • Northwest
      • G23
      Don't think this is the issue, as they don't really turn on - the fault happens immediately. It also happened on the water that last time I tried them, but the engine was running and I thought it might be a alternator/voltage regulator issue. Given it is happening with the engine off, that is not likely.
      • Scoma
        • Jul 2017
        • 31
        • Charlotte, NC
        • GS 22
        My GS 22 had that happen. They replaced both lights.
        • GMLIII
          • May 2013
          • 2795
          I had one of my underwater lights replaced as well under warranty
          • blueroom
            • Mar 2017
            • 623
            • Northwest
            • G23
            Scoma and GMLIII - Good info. Did the bad lights cause circuit faults? Or did they just not work?
            • GMLIII
              • May 2013
              • 2795
              No it just didn’t work . Loose connection and the light cut on and off so dealer replaced
              • blueroom
                • Mar 2017
                • 623
                • Northwest
                • G23
                As suspected, the underwater light circuit fault - overcurrent - was due to a bad underwater light. Replaced and good to go.
