Roswell HCLD Upgrade
  • UruPablo
    • Apr 2019
    • 2
    • Uruguay
    • 2012 SAN 210
    Originally posted by SXRNathan View Post
    If you have any other pictures that would be great. Looks like this is going to be a winter project.
    Let me know if you need one specific picture. I am using Wet Sounds HTX-2 600W RMS 2 channels to move the 6x9.
    Its a good winter project.
    Sent from my SM-G985F using Tapatalk
    • SXRNathan
      • Mar 2014
      • 26
      • Edmonton
      • 2011 Sport Nautique 200V.
      So winter has turned to spring and I am finally starting this project. Looks like the rubber part of the WS speaker will touch the edge of the can. Does it? I am wondering if I should open up the hole? I have access to a milling machine and could make it clear.
      what did you do for the crossover? Use the Roswell one or the Wet sounds? If you used the wet sounds, did you jus cut out the factory one?
      • MLA
        • Dec 2009
        • 1312
        • Lake Wylie NC Area
        Ive not found any contact issue between the pod and new drivers.
        The Rev 696RS is all in one, so only a single + and - that you connect the pod's speaker leads to. Nothing associated with the old drivers, is reused.
