FM Antenna
  • d_nodixon
    • Sep 2008
    • 475
    • Hammond, LA
    • 2013 SAN 230
    FM Antenna
    What's the secret to getting good FM reception? My preference is a hidden type antenna. I bought an antenna from Best buy to lay under the front seats....a minor improvement but not good enough. I have Googled multiple antenna but have found nothing with consistent reviews.
    Sent from my Pixel 2 using PLT Nautique mobile app
    2013 SAN 230
    2006 SSN 210 (SOLD)
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    Well, this is not really a problem that can be solved easily. The only way to get good FM reception is with an antenna sticking up perpendicular to the boat. But that's ugly. So most people end up trying to hide it somewhere which severely limits its ability to pull in a good signal. If the transmitting antenna is close by this can work, but outside of that you're out of luck.
    I gave up on this years ago and just went with satellite radio.
    -Charles
    • Wake.BC
      • Jan 2016
      • 423
      • BC, Canada
      Giving up is your best answer. Who uses fm now a days anyway?
      • Nautiquehunter
        • Jun 2008
        • 2080
        I have never had luck with FM on water go with Bluetooth or Ipod.
        • DealsGapCobra
          • May 2010
          • 375
          • Knoxville, TN
          • Ski Nautique 200
          I added a hidden powered antenna to my boat it is slightly better than just the wire but not worth the effort...and it was little effort.
          • d_nodixon
            • Sep 2008
            • 475
            • Hammond, LA
            • 2013 SAN 230
            Thanks for the advice....we usually go the Pandora route but have several locations without a signal. My buddy's MC tends to get good FM reception, will have check out his setup.
            2013 SAN 230
            2006 SSN 210 (SOLD)
            • kdonzi123
              • Nov 2012
              • 88
              • Lake Hopatcong
              • 2018 230
              Based on the Antenna problem, I found out that my 2018 230 the Factory hooks the antenna wire to screw on the rub rail , there for the whole rub rail becomes the antenna. I would take out the screw and replace it with a Stainless machine screw with a lock nut and try that.
              • d_nodixon
                • Sep 2008
                • 475
                • Hammond, LA
                • 2013 SAN 230
                Ok...does you 2018 get good FM reception then? Sounds like a reasonable fix.
                2013 SAN 230
                2006 SSN 210 (SOLD)
