adding underwater lights
  • kylant
    • May 2010
    • 538
    • Lake Tahoe
    is it possible to add underwater docking lights to a boat that did not come with them from the factory? If so, how challenging? what all is involved? I am looking at a new GS20 and it does not have them. They are an option I have always wanted
    thanks
  • MLA
    • Dec 2009
    • 1312
    • Lake Wylie NC Area
    Not an impossible job, just need to take a few precautions when mounting underwater hardware. Most boats offer it as an option, so if you locate the factory harness, you may be able to utilize that, depending on the lights you go with. However, the output may be deactivated in your LINK and would need to be activated through the dealer menu.
    Proper placement of the light for wire access and best light effect, proper underwater sealer, drilling and hole prep, etc.
    • kylant
      • May 2010
      • 538
      • Lake Tahoe
      thanks again for the info.
      I would be using the Nautique factory lights. Are these a plug and play option? Dealer activation in Link should be easy. I may just have the dealer do it all
      • jrhollow
        • Oct 2017
        • 1
        • Minneapolis
        • 2017 GS22
        I had the dealer install them on my GS22 over the winter. They look like they came from the factory.
        • distinguishedmotorsports
          • Aug 2016
          • 482
          • Austin, TX
          not plug and play, more like crimp positive and negative leads and then play. at least my 2010 230 just had crimps on the end of the factory underwater harness that i replaced with water proof heat shrinks. its near the harness for the blower.
          • kylant
            • May 2010
            • 538
            • Lake Tahoe
            do you by chance have any info on this?
            thanks
            • Millerda68
              • Apr 2018
              • 50
              • Forest Grove, OR
              • 2017 Super Air Nautique GS20
              Also interested in this thread. I just purchased a '17 GS20 and am interested in adding the lights. Also, how's the output on the factory lights? I was looking at the Roswell lights as an option. https://www.roswellmarine.com/product/nightwave/.
              • beamons
                • Jun 2017
                • 376
                • Utah
                Millerda68 I am not sure if you are looking for docking lights or rear lights. If rear see below.
                Several posts on here but one I think is the best:
                https://www.planetnautique.com/vb5/f...surfing-set-up
                The short story sounded to me is that the Liquid Lumens were the best.
                  • Aug 2016
                  • 482
                  • Austin, TX
                  these are what i run, they also have an RGB which is on my current boat. https://www.superbrightleds.com/more...-60-watt/3315/
                  • Millerda68
                    • Apr 2018
                    • 50
                    • Forest Grove, OR
                    Thanks! I will check these out.
