My amp for my tower speakers quit so I am looking for some input . The currant set up is a Diamond D3400-2 2 channel powering 2 Fusion T series tower speakers. I don't want to get louder and don't want to break the bank with high end amps that will never be used to capacity . I am looking for a good brand 2 or 4 channel amp 400 watts or more and try to keep it under 200.00 if possible.
I have been running a planet audio AC800 800 watt 4 ch in my jeep for about a year now. It's on amazon prime for $66.62.
https://www.amazon.com/Planet-Audio-...et+audio+ac800Last edited by Shawn Henderson; 05-29-2018, 11:58 AM.
Originally posted by Shawn Henderson View PostI have been running a planet audio AC800 800 watt 4 ch in my jeep for about a year now. It's on amazon prime for $66.62.
As far as I can tell your speakers are 200W RMS and I'd guess 4ohm (but couldn't confirm). To stay in budget I'd just get a car amp. Should last years is kept dry.
I just picked up a NVX JAD800.4 which should be around $200. Bridged it will put out 400W per channel at 4 ohms. Which should be plenty of power. If your speakers are 2 ohms it will put out 200W per channel, using only 2 of the available channels and the other two can be used to power your in boat speakers.
You won't get that kind of output from a marine amp unless you spend twice the money.
For a single pair of 4 ohm 6.5 coaxial, the Kicker KMA300.4 bridged 2 chnl is the way to go for both quality build, marine built and solid power.
Very good questions, Blamey
Price: the Kicker at regular retail is only$50 above his price point. Factor some typical discounts, and one gets a decent marine amp close to his price point.
Output:, that "400 watt" diamond amp comes out to only 100W RMS per chnl to a pair of 4 ohm speakers (based on 2 sources). Thats 50W RMS less then the Kicker KMA300.4 I suggested.
Marine built, we covered
Class-D, so its way more efficient
