Howdy. Had to tear apart my boat trying to track down why i was lost in cabine speakers. Only the tower speakers were working. Unfortunately I bought the boat w/ the setup installed, so I knew nothing about it. I tracked it down to a bad amplifier it looks like. Can't get all 4 channels to consistently work. What's weird is that I was able to switch (not intentionally) which channel would not send signal. I could use some help with a replacement/replacements. Frankly i find the setup a little weird and not sure if i want to replicate it. I'm also budget and weight conscious however.
Roswell 800.5 5.1 amplifier. Power: 75W x4 + 250W @ 4Ω / 100W x4 + 375W @ 2Ω (BROKEN)
X4 Clarion CM1620A 100w max 4ohm speakers. I think these might have been stock. Seen better days by the looks of it.
Focal 245A4 10" sub. 4ohm. 200w rms
X2 Roswell Aquatone Pro HLCD speakers. 4ohm. 100w rms
I found that the 4 clarion speakers were wired up to two channels. I'm guessing it was probably in parallel to give run the 2 channels a 2ohms. The sub and tower speakers were ran off the remaining channels at 4ohms. What i don't like is that the boat speakers were only getting 50w and the towers were getting 75w. One, that's not much, and two it's uneven.
I also had no way to fade out the tower speakers b/c they split the signal off the receiver from the front input only and didn't use the rears.
Looking for advice on what amplifier/s to purchase. I'm tempted to say i'm just looking for another one a done, due to space and weight and not wanting to drive my alternator too hard. I understand it's not that large on the GT-40s. Also looking for recommendations on new cabin speakers and whether to run them free air or sealed. Right now they'red in a teeeny tiny sealed enclosure. THANKS!
