Ok I feel like an idiot. How do you setup the auto volume? I can't see how to adjust the speed/volume paramters and the manual is no help.
Edit:.
I just found the answer buried in another thread by member Wayward: "...the '16 speed volume is awesome. Instead of it using its own randomly determined levels, it works like- Turn speed volume on. While at idle, set your desired level. pull your rider up and Accelerate to the cruise lock in point and set your own desired high level........ rider falls and the system will go back down to your set low level. pull them back up and it will go back to your set high level.....every time. Wanna tweak it? simple- just set your new high or low level while the boat is at the desired set point."
Edit:.
