2103 G23 tower speaker replacements??? Recomendations
  • surfnjosh
    • Jul 2016
    • 104
    • Canada
    • 2021 G23 2020 G23 2017 G23 2013 G23 2012 230 Team
    My factory tower speakers sound like garbage. It has the 4 6x9 horn loaded Roswell things from the factory with the downwards facing lights. Is there any speakers I can buy that will replace these and use the same enclosures??
    What are my best options here?
    Any recommendations?
  • MLA
    • Dec 2009
    • 1312
    • Lake Wylie NC Area
    if you look close I think you will find they are round 6.5" HLCD. They appear to be a 6x9 with the use of a trim filler. The Wet Sounds 6x9 HLCD or the Kicker PS694 coaxials are proven options. Both are am improvement over a 6.5" HLCD
    • surfnjosh
      • Jul 2016
      • 104
      • Canada
      Yes I'm sure you are correct. So what your saying is those 2 6x9 options you gave will fit in my factory enclosures? Happen to have any pictures of this swap?
      thank you for the reply/ advice.
      • Cpan13
        • Jan 2016
        • 342
        • Canada
        • Current - 2021 G23 … Previous - 2020 Supra SL450, 2015 G23, 2014 G21, 2012 Epic 21V
        How do the kicker compare to the wetsounds for wakeboard distance?
        • MLA
          • Dec 2009
          • 1312
          You can set any brand names aside. An HLCD is going to be the better setup for wake range projection and the coaxial is going to yield warmer sound quality near field.
