Perfect Pass not working
  • RJP56
    • Jul 2008
    • 84
    • Winchester Center, CT.
    Our boat has a Perfect Pass 6.0. Sometimes when I started it, the perfect pass would continually beep. It seems like if I went under the boat, and spun the paddle wheel it would stop. Might have been some weeds in there or something. The paddle wheel trick doesn't seem to be working anymore and it just beeps. Any ideas what cause cause this? Anything we could do besides upgrading?
  • Big3Skier
    • Jun 2017
    • 16
    • Ohio
    when it beeps does your display look funny ? - if so the display might be going bad. Happened to me. One other thing you can try if you display is fine is give your battery a good charge - your battery should be around 12.7 or 12.8 and if it's low it will freak out Perect Pass.
    • RJP56
      • Jul 2008
      • 84
      Thank You, The display looks fine when it works. I just see a bunch of black boxes on there now. I will check the battery. The boat doesn't get used to often so that might be the problem.
