GPS Speed control dropping out.
  • kdonzi123
    • Nov 2012
    • 88
    • Lake Hopatcong
    • 2018 230
    Has anyone had a problem with the perfect pass dropping out on there 2011 , 230. We are having this issue were is will work for a few Min then stop working and we have to
    use the RPM mode. Any help would be great.
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    Well first thing to check is the GPS antenna. The only time I had trouble with mine was when someone kept draping their arm over it while underway. Outside of that, start tracing cables. Definitely find where it plugs into the boat's wiring harness and disconnect/reconnect it there. If it was loose, find some way to tape it up so it doesn't come loose again.
    -Charles
    • kdonzi123
      • Nov 2012
      • 88
      • Lake Hopatcong
      • 2018 230
      Thanks we are going to start with that first.
