2008 radio blowing fuse in amp
  • wakehead
    • Dec 2009
    • 240
    Hi all,
    Last time I went out on the lake I lost all sound in my speakers and something is shorting one of my amps out. My subwoofer is working as it is connected to a separate amp but for some reason the other amp which drives all the speakers in my boat blows both 30 amp fuses. I changed them turned on the power and they immediately blow. Something is shorting it and I don’t know where to start. Any help is appreciated.
    210 SANTE
  • MLA
    • Dec 2009
    • 1312
    • Lake Wylie NC Area
    So the breaker/fuse trips/blows as soon as replaced/reset or as soon as you turn the head on? Disconnect the B+ power cable and replace/reset. If the fuse/breaker remains intact, its likely internal of the amp.
    • wakehead
      • Dec 2009
      • 240
      Thanks for this. What I did was turned the battery to off. Replaced the fuse, turned the battery of the boat back on and poof. Immediately blew the fuses.
      What do you mean by the B+ power cable ?
      210 SANTE
      • MLA
        • Dec 2009
        • 1312
        B = battery
        + = positive
        • wakehead
          • Dec 2009
          • 240
          B = battery
          + = positive
          Does the power need to be on to reset the amp, or should the power in the boat be completely off before I reset ? Not sure if amps reset properly with zero power.
          Thanks for for all the help
          210 SANTE
          • MLA
            • Dec 2009
            • 1312
            Without knowing the amp model, I cannot comment on any type of amp reset procedure. However, if you know the model, you can google and finds owners manual. It may describe and a reset procedure.
            • wakehead
              • Dec 2009
              • 240
              Hi there. So I did some troubling shooting this weekend. No luck yet, but here is what I did. First of all there is no reset on the amp. It is a clarion xc6420. I ran out of fuses from them blowing but what I did was unplugged all the speakers and tried to put the fuses and they fried. This leaves me with 2 more options. Check the ground and the power. I am not sure how to do this with a volt meter. Anyone have any advice or links for me to check the ground and power ?
              Otherwise I guess the amp is fried. Before buying a new one I want to make sure that it is the amp obviously.
              Thanks for your help
              210 SANTE
