Speed Control and Speedometer Wigging Out
  • dklauer
    • Aug 2017
    • 10
    • South Bend, IN
    I have a 2013 Sport Nautique 200. Sometimes digital the GPS Speedometer works great and no issues with speed control. Other times it's completely non functional. The GPS antenna isn't covered or blocked....Any insight?
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    Check the connection from the antenna into the module. Disconnect it, look for any kind of corrosion and clean as needed. This is a good place to start.
    -Charles
    • kdonzi123
      • Nov 2012
      • 88
      • Lake Hopatcong
      • 2018 230
      More than likely its the GPS puck . My friends 2011 is doing the same thing. Dealer put a test unit in and worked fine. You should be able to go into the link screen under setting and see the SAT that its picking up. Good luck
