2005 210 Subwoofer Options
  • Stevemo14
    • Apr 2019
    • 691
    • Columbus, OH
    So I have a 2005 210, and I need to do something different with my sub-woofer. I currently have a 12" L7 Solobaric in a sealed enclosure under the observers seat. That leaves me pretty muck 0 room for storage down there. Once i cut the cooler out of the bow and put the 750# V sac in i will have 0 storage. So with that being said i was thinking of selling the 12"L7 and getting a Wet Sounds Revo 12 FA ( Free Air ). I think i have 2 options for the placement under the driver console or in the pass through to the bow on the port side ( Observers seat side )
    Has anyone done one, both or different methods that can give me some recommendations? I'm not stuck on the 12" Sub either but that would be my preference. I think the easiest way would be to put the hole in the pass through , and mount it there, but i don;t know if that panel will hold a 12" sub and the vibrations it will cause.
  • JAppler
    • Apr 2019
    • 167
    • FL
    I’d like to know too... I am currently looking around on ideas for a complete system for an 04 210... and I am seriously considering something similar. Also im wondering if 7.7 will fit face mounted in the stock holes...
    • Stevemo14
      • Apr 2019
      • 691
      • Columbus, OH
      I did a complete Wet Sounds ( sans the sub-woofer ) setup in mine this past spring. I did the Revo 6 speakers for the in boats. There were a direct fit for the existing holes. The Revo 6 needs a 5" hole cut out, the JL 7.7 needs a 6.25" cut out. Now that being said, I think you could make the hole 6.25" with a little bit of work. The Side mounting boards are easy to modify, you would just have to be careful of the vinyl.
      • core-rider
        • 1350
        • Huntsville, AL
        • 2003 Black SANTE
        I actually just began this project this past weekend. I had my SA-12 in a ported enclosure under the driver's dash, but it didn't leave much space for my feet. I cut the "hump" out behind the false wall and will fiberglass over the whole it left... This will allow about 5-6" more for me to push the enclosure back. I'll build a new false wall, remount the 6.5" speaker, and breaker panel. Not the easiest job, but should look clean and be more useful in the long run, plus it will help protect the sub as well.
        Jason
        All black 2003 SANTE
        -- Southern Fried --
        • markj
          • 1194
          • NorCal
          ^^^That is exactly what I had done on my 2005 210 and loved it. There was just a slot for the vent. It sounded really good. I had a heater hose as well. It all fit. I need to find pics.
          • core-rider
            • 1350
            • Huntsville, AL
            • 2003 Black SANTE
            Man if you can find pics that would be great! I'm still worried there won't be enough room to put the circuit breaker panel and the 6.5" speaker back in place. My idea was to mount the circuit breakers panel up under the dash out of site. Where was your's mounted?
            Jason
            • Warrior48188
              • Aug 2017
              • 23
              • Michigan
              • 2004 SAN
              I'm in the same position as you. I need to find a location for my 10" wet sounds FA sub. If you place the sub in the walk thru, I'm thinking you could reinforce it from the backside (use brackets at the top and bottom to anchor it in). I removed my kick panel today and noticed removing the hump would only gain me an inch or two. I'm leaning towards installing the sub in the walk thru (passenger side.
              • MLA
                • Dec 2009
                • 1312
                • Lake Wylie NC Area
                With an Infinite-baffle woofer, under the helm would be less then ideal anyway, as the false wall is, well, open at the top. Could you place an IB (FA) woofer in a small sealed enclosure? Sure, its just not the best application for that woofer.
                • markj
                  • 1194
                  • NorCal
                  I’m so bummed I can’t find any pics! I traded that old boat in to a dealer across the country and have no way to contact the new owner. My circuit breakers were under the dash like you're talking about. The custom Fiberglass/MDF hybrid sub enclosure was ported. It was a 12” Digital Designs sub that would blow the hair on my legs back. The place that built the custom enclosure was called Chucktronics in Lodi, Ca. They’re out of business now. The new panel had the slotted sub port, the 6.5” speaker and the heater hose outlet all in the same carpeted panel that stuck out about 5”-6” further towards the driver’s seat than stock. I remember we had to cut a bit out of the top left of that panel so we could still access the ballast valves.
                  • markj
                    • 1194
                    • NorCal
                    Man, I’ve been there with the free air subs and what a total waste those are. Either do it right or forget it and save your money. I’m sure you know that better than anyone here.
                    • core-rider
                      • 1350
                      • Huntsville, AL
                      • 2003 Black SANTE
                      I’m running a 4” aero port because quiet simply it’s easier to build than a slot port enclosure for me. Sub sounds great... I just want a more clean look and foot space. I’ve removed the ballast valve knob panel to make a bit more room, plus I don’t use those anyway since they are almost useless. I plan to do a small DIY thread once I’m done with the project so hopefully others will find it useful. Thanks for the info!
                      Jason
                      • MLA
                        • Dec 2009
                        • 1312
                        LOL, you must be reading one thread and posting in another, thats no where close to what I said
                        • markj
                          • 1194
                          • NorCal
                          Cool. I look forward to seeing it. I’ve loved your boat for 15 years and was so butt hurt when if found out I couldn’t order mine all black in 05.
                          • markj
                            • 1194
                            • NorCal
                            Hahaha! Whoops! You’re probably right. Thanks for clarifying. I was beginning to think you lost it! Lol
                            • Chuck
                              • Mar 2016
                              • 63
                              • Paradise, Ca
                              • 2005 SAN 210
                              What did you fill in the hole with? Thanks.
