2020 SAN volume strange
  • mattgboucher
    • Jun 2020
    • 5
    Anyone have an issue where the colume is really low under volume 30 then gets to a max of 50.
    However if i continue to turn the volune above 50 it continues to get louder. Seems like the starting point is wrong.
  • mattgboucher
    • Jun 2020
    • 5
    so turns out that i had the tower volume muted and had adjusted both the sub and cockpit volumes way lower like to 10 when the tower was at 30.
    • mattgboucher
      • Jun 2020
      • 5
      adjusted them all to be the same now volume is in sync again
      • charlesml3
        • Jan 2008
        • 2482
        • Lake Gaston, NC
        • 2022 G23
        So you'll probably adjust this again. Most likely you'll end up with the tower louder than the cabin. Mine pretty much stays that way.
        -Charles
