Adding gps fishfinder to 95 Ski Nautique
  • deadlander
    • Jul 2020
    • 13
    • DeLand, Fl
    • 1997 Baycraft 15' 1995 Ski Nautique 196
    Well looking to add a Lowarance hook2 gps to my 95 Ski Nautique to help navigate the river plus fix a very flakey depth sounder. Only issue is the hook2 only has a transom mount transducer. After doing some reading this may not work with an inboard due to prop wash. Has anyone had any luck installing a transom mount transducer on their Nautique?
    Anyone have a gps depth sounder recommendation that uses as in hull transducer? Thanks for the advice looking foraged to busy spring summer on the St. John’s.
    Regards,
    Al
  • wayoutthere
    • Feb 2020
    • 328
    • 1995 retired, restored/upgraded a-class raceboat 1979 ski nautique in need of the above
    You should be able to buy either a thru hull transducer or shoot thru transducer as an upgrade.
    i would put the transducer in front of the 1st tracking fin.
    • srock
      • Oct 2008
      • 1066
      Transom mount will work you just need to be to on either side of the prop wash in clean water. I would look at the water coming off the hull while under power to see where its clean. An alternate and better option in my opinion is the find a unit that will work with a thru hull transducer mounted in clean water. I don't think tracking fins would be an issue when mounted off center nor would you want it mounted in the center of the keel. Use your water pickup as a guide and place it on the opposite side of the hull.
