G23 dual subwoofer porn
  • tunafoot
    • Apr 2018
    • 15
    • Phoenix AZ
    With a little inspiration from StormTrooperZ28's build, I decided to do a dual inverted subwoofer setup on my 2014 G23.
    Click image for larger version  Name:	G23 1.jpg Views:	0 Size:	36.1 KB ID:	635916
    I used WinISD to design the box. I typically build my subwoofer boxes using a slot port but selected a 6" flared port to vent into the walkway instead.
    Click image for larger version  Name:	G23 2.jpg Views:	0 Size:	38.6 KB ID:	635917
    Click image for larger version  Name:	G23 3.jpg Views:	0 Size:	45.1 KB ID:	635918
    Click image for larger version  Name:	G23 4.jpg Views:	0 Size:	130.1 KB ID:	635919
    Click image for larger version  Name:	G23 5.jpg Views:	0 Size:	67.7 KB ID:	635920
    Click image for larger version  Name:	G23 7.jpg Views:	0 Size:	40.2 KB ID:	635921
    Click image for larger version  Name:	G23 8.jpg Views:	0 Size:	46.6 KB ID:	635922
    Click image for larger version  Name:	G23 9.jpg Views:	0 Size:	52.0 KB ID:	635923
    I installed a Helix Psix DSP and used Room EQ Wizard To flatten the frequency response peaks & dips
    Click image for larger version  Name:	G23 10.jpg Views:	0 Size:	53.4 KB ID:	635924
    I covered the box to match the existing vinyl.
    Click image for larger version  Name:	G23 11.jpg Views:	0 Size:	80.9 KB ID:	635926
    Sounds as good as it looks and I was able to keep the factory garbage can.
    Click image for larger version  Name:	G23 12.jpg Views:	0 Size:	33.3 KB ID:	635927
  • cblackburn
    • Apr 2021
    • 3
    • Granite Bay, CA
    • 2017 G23
    Clean!
    • srock
      • Oct 2008
      • 1066
      That made my ears bleed.
