With a little inspiration from StormTrooperZ28's build, I decided to do a dual inverted subwoofer setup on my 2014 G23.
I used WinISD to design the box. I typically build my subwoofer boxes using a slot port but selected a 6" flared port to vent into the walkway instead.
I installed a Helix Psix DSP and used Room EQ Wizard To flatten the frequency response peaks & dips
I covered the box to match the existing vinyl.
Sounds as good as it looks and I was able to keep the factory garbage can.
