2009 230 adding HTX-6 and new HU. Can I use factory power wires.
  • Blamey
    • Sep 2015
    • 595
    • New York
    My basic question is what is the breaker switch rating for the factory amps (I have a Team Edition). Looking online most panels seem to have 60amp breakers for each amp but the examples I can find are usually newer boats.
    Additionally looking for any advice from someone who has done a similar upgrade before. Anything I should be aware of or tackle now while I am working on this.
    My speaker setup is as follows
    RMS Impedance Quantity
    Cabin Wet Sounds XS 650 100 4 4
    Bow Polk MM 651UM 100 4 2
    Tower Polk MM 692 150 4 2
    Sub JL M10IB 250 4 1
    Amp is going to be a HTX-6 and I also have a WS420
    I am upgrading my 230 Amp to a single WS HTX-6. Plan is to run Sub, cabins and tower speakers off this and run the bow speakers off the head unit. Since I don't think the factory wire will support the HTX-6 (by my calcs it will need around 90 Amps, I am going to use the both power wires from the factory.
    My plan is to update the tower speakers and add another amp at the point. When I do that I will upgrade the wiring power and ground wires to a single 1/0 run from the battery but I was going to wait on this until I know exactly what I am going to get.
  • Blamey
    • Sep 2015
    • 595
    • New York
    Follow up question. Does anyone know the length of power and ground wire I'd need If I was going to upgrade the wiring from the battery switch. An estimate would be fine.
    • MLA
      • Dec 2009
      • 1312
      • Lake Wylie NC Area
      If im reading this correctly, you are asking if you can run the two factory amp power cables to a single amp? No, I would not advise to do this. You need adequate cable gauge for both the B+ and B- as well as proper circuit protection for the amp and cable. Personally, I would not run anything smaller then 4ga to that amp.
      • Blamey
        • Sep 2015
        • 595
        • New York
        Thanks MLA,
        Do you know what length the run from the amps to the battery switch is?
        • MLA
          • Dec 2009
          • 1312
          If the switch is in the STBD rear locker, you are likely looking at 25ft for the B+. Less for the ground. Maybe 15ft to the battery under the port side corner cushion.
