Help! Rear speakers not working.
  • camman621
    • Sep 2006
    • 7
    I've got a 2003 210 TE. My bow and tower speakers work fine, but for some reason my rear four speakers aren't putting out any sound. I checked the fader and balance settings on the headunit, and those are both set correctly. Does anyone have any suggestions on what might be causing this and how to fix it? Thanks.
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    RE: Help! Rear speakers not working.
    Check the AMP. Make sure the fuse isn't blown or that there is power to it.
    Nautiqueless in San Diego
    • Flux
      • 408
      • Palmdale, Ca.
      Yep, check the amp. Usually the bows are run off the head unit. The rear 4 speakers and the sub are off the amp. Check the fuses first, if they are good turn on the HU and make sure the amp is remote triggering, it should simply turn on.
