2010 SAN 210 Head Unit Replacement
  • Kollstal
    • May 2022
    • 10
    • Seattle, WA
    • 2010 SAN 210 Coastal
    I have recently purchased a 2010 SAN 210 and am looking to upgrade the head unit (and possibly the remote) from the original Clarion CD Player to something else. Should I stay with Clarion, or move to something else (Polk Audio, JL Audio, etc.)? FYI - Linc 2.0 was installed in the boat, which I am told isn't common for a 2010? Thanks for any recommendations.
  • SwiftnessNautique
    • Aug 2018
    • 38
    • Austin
    • 2006 SANTE
    Kollstal - Where do you plan to install the head-unit? Original location?
    • Kollstal
      • May 2022
      • 10
      • Seattle, WA
      Yes, the original location in the glove box area.
      • SwiftnessNautique
        • Aug 2018
        • 38
        • Austin
        • 2006 SANTE
        Ton's of good options out there. Rockford makes good units, along with Wet Sounds $$$. As long as it is marine grade and has enough outputs needed to push your amps you should be good.
        • MLA
          • Dec 2009
          • 1312
          • Lake Wylie NC Area
          To be fair, Rockford's top unit is only $50 less then Wet Sounds top unit. Rockford's next 2 units cost more then Wet Sounds next 2 units. Just sayin........................
