2015 Tower Speaker Replacement
  • HHSuperAirG25
    • May 2022
    • 6
    • WA
    • 2015 Super Air Nautique G25 Coastal
    I'm looking to replace my 2015 Focal K2 tower speakers and didn't realize they each have a crossover board in the can for the speakers.
    Q: Can i simply replace with new 2-way Coaxial like Wet Sounds or Rockford without the crossover? One of the boards looks fried anyway.
    Thanks in advance!
  • Tank2112
    • Jun 2023
    • 2
    • FL
    • 1995 Sport Nautique GT40
    The crossover controls frequencies sent to tweeter/driver. You need some sort if crossover for replacement speaker, unless bi-amping… using two channels from an amp and using crossover in amp to limit frequencies. or could use an external 2-way crossover and two sets of speaker wires per tower speaker housing.
    • MLA
      • Dec 2009
      • 1312
      • Lake Wylie NC Area
      A new Wet Sounds or Rockford coaxial will have its own onboard cross-over. Take the incoming wires directly to the new speakers, bypassing the old cross-over.
      • HHSuperAirG25
        • May 2022
        • 6
        • WA
        Thank you, both. I assumed the new speakers should have it built in but wasn't finding a clear answer.
        • bturner
          • Jun 2019
          • 1564
          • MI
          • 2016 200 Sport Nautique
          I really like my JL's if you want to go with that factory look.
          • HHSuperAirG25
            • May 2022
            • 6
            • WA
            do you recall which model you put in? I've had mixed success with JL, but the good has always been great
            • MLA
              • Dec 2009
              • 1312
              JL does not offer a drop-in 6x9 driver for his existing pods, but rather a complete pod/mount swap. Not saying not to go this route, just that the OP needs to know this is a more expensive path v's just replacing the drivers.
