Speakers not working 2008 Super Air Nautique
  • thawk0414
    • Sep 2023
    • 3
    • Ohio
    • Super Air Nautique
    I have several speakers not working. Is there a wiring diagram for the Clarion audio system?
  • Scooter G
    • Jan 2022
    • 1320
    • On a Lake in Idaho
    • 2022 G23 ZZ8
    For what it’s worth, have you tested the speakers? You can use a 9V or AA (fairly accurate), and you will get a popping noise when applied to the speaker terminals, quick applications not extended. A more accurate text would be a multimeter testing ohms. I had a blown sub when I purchased the boat and I got an open reading, 0 ohms. You can test the speaker wire output by using a millivolt setting, turn on some sound, you should get a reading that will vary based on the audio output. I usually start at the speakers and work backwards. You should be able to run these tests at the head unit also, I am assuming RCA jacks on an ’08, or change plugs with a known good speaker to one of the bad speakers.
