2019 G23 Cockpit speakers malfunction
  • davidmamato
    • Oct 2013
    • 44
    • westminster, ca
    2019 G23 Cockpit speakers are stuck on full volume (50) and no sound coming from cockpit speakers. Any help greatly appreciated!
  • Maksim.N.
    • Nov 2023
    • 9
    • WA
    • 2022 Nautique G23 ZZ6
    Would be great idea to check all the wire connectors and apply Di-Electric Grease Left unprotected, these connections may produce arcing, shorts and electrical fires.
    • Scooter G
      • Jan 2022
      • 1320
      • On a Lake in Idaho
      • 2022 G23 ZZ8
      Additional details would be wonderful for the Forum, and it seems I have seen a similar post in the archives.
      When did this 1st happen?
      Did you do a batteries off reset?
      Is the rest of the system working, other speakers, subs?
      Condition of batteries, and any other current issues?
      Have you done a visual on the connections under the sunken living room (things get bumped in there)?
      Deutsch connectors are pretty bullet proof, but a little dab of Di-Electric Grease on connectors is never a bad idea in a high moisture environment, and also on the RCA jacks, as Maksim.N. mentioned.
      • davidmamato
        • Oct 2013
        • 44
        • westminster, ca
        First happened when Samsung phone was plugged into USB port near radio head (USB port with both lightning bolt and music symbol). I have turned the battery switch off, when the boat is not in use the battery switch is in the off position. The rest of the speakers are working properly. Batteries are showing proper voltage. Next step is to check all connections on the rear of the radio head and amplifiers. Boat has 145 hours, stored in indoor storage unit with cover. I do not think it is a moisture issue. If I had to guess it appears to be a software glitch. Any help is greatly appreciated!
        • Scooter G
          • Jan 2022
          • 1320
          • 2022 G23 ZZ8
          I did find this for what it's worth (maybe you've already seen it):
          https://www.planetnautique.com/vb5/f...k-50-max-fixed
          • davidmamato
            • Oct 2013
            • 44
            • westminster, ca
            Thank you Scooter G, I will post outcome after I try.
