Could I get some feedback/input on this setup that I have drawn out below? I'm not even close to being an expert at any stereo setup, so I hope that I can get some audiophile's to let me know if there are any problems with the way that I have drawn out the diagram.
Basically, I'm running off of the XMD3, PPI PAR-650 Preamp, MTX 942 Amp (2-channel for tower speakers), MTX 564 (4-channel for interior speakers), Polk MM2104DVC subwoofer, MTX 801D (Mono amp for Sub).
I would like to have the 4-channel setup in the interior, so would it be a bad idea to set up the system with the Front outputs split - so the signal ends up going to both the Tower amp and interior speaker amp?
To simplify the drawing, I didn't put in the sub or amp for it - the Preamp has a sub output so it will run directly off of that.
I plan on controlling the level of the tower speakers by way of the MTX EBC level control (basic turn knob).
All of the lines are RCA cables, with the exception of the lines going to the speakers.
So, will this work or no? I would appreciate any help.
Thanks much.
Thanks much.
