Mounting block adhesive
  • LT206
    • Mar 2006
    • 262
    • Huntsville, AL
    I'm making some small mounting blocks to glue under the bow areas in order to use some of those screw attached zip ties to mount my power cables to. What type of glue will work to glue the mdf blocks to the fiberglass. I've seen this done somewhere but I can't find the link to see what's glue was being used.
  • Labatt911
    • Sep 2004
    • 110
    • NE Ohio
    • None Currently : ( 1999 Pro Air 1998 Sport/Air
    RE: Mounting block adhesive
    Liquid nail should work
    ** Be Not Afraid **
    • MHayes
      • Aug 2004
      • 830
      • Roswell, GA
      Liquid nails is ok (you really have to watch how much you put on the block, because more is not better in this case), but I found the Loctite 2 part epoxy to be much better and much stronger. You can find it at Home Depot or Lowes.
      2001 Air Nautique
      • LT206
        • Mar 2006
        • 262
        • Huntsville, AL
        I knew there was a good solution, I just didn't want to have to learn the hard way by doing it wrong the first time - thanks for the replies.
