This topic has come up quite a few times, and I have spent most of the day today researching how to do this. I've spoken with Clarion and Crutchfield, and even after that, I find Grant (whitechocolate) to be the best source of information on this topic. I have compiled my findings, most of which came from Grant. A good portion of this information came from this thread over on WakeWorld.
Clarion XMD-1 and XMD-2 Stereos
If you have a Clarion XMD-1 or XMD-2, which you probably do if you have a stock stereo in your pre-2004 Correct Craft, there are two options. For those of you who are wondering if you can hook up an iPod to the CD changer input on the XMD-1 or XMD-2, the answer is NO. There is no cable available that converts the C-Bus input on the back of these stereos into anything usable for an iPod. I have done an exhaustive search.
Clarion XMD-3 Stereos
If you have a Clarion XMD-3, which you probably do if you have a stock stereo in your 2004 Correct Craft, you have it easy.
First, purchase a conversion cable that converts your iPod's output into RCA.
Next, connect your RCA cables to the Auxilary Input on the back of your XMD-3 stereo. They're the red input wires.
That's it! You can now listen to music from your iPod through your XMD-3 stereo.
- A. You can use an FM modulator to transmit the signal from the iPod to the radio. This is considered to be the less desirable of the two options because sound quality WILL go down using this method.
B. You can purchase a pre-amp, which will allow for the connection of an external device. Grant has the Rockford Fosgate PA2. It has an A/B switch that enables the user to switch between the signal from the head unit and the signal from the external device (iPod, etc.).
