Subwoofer advice
  • skiking
    • Jun 2007
    • 118
    • TX
    Subwoofer advice
    I know there are many of you that have already overcome this obstacle. I have a 1999 Super Sport Nautique and am looking for some subwoofer placement suggestions. Do any of you have any pictures of places you have put your subwoofers on these late 90’s or early 2000 year Super Sports? Space is pretty tight. Any help would be greatly appreciated. Thanks in advance.
    PerfectPass Wakeboard Pro
    100amp Alternator Upgrade and 2 - Optima Blue Tops
    Wetsounds, JL Audio, Alpine sound system
    3-Jabsco Ballast Puppies
    1- Fly High Center Sack 650lbs and 2 - Fly High Rear 750lbs
    Ballast Install - http://planetnautique.com/vb3/showth...allast-Install
  • Sinkoumn
    • Jun 2006
    • 578
    • MPLS - St. Paul, MN
    • Super Sport Nautique
    RE: Subwoofer advice
    I put mine right behind the kickpanel. Space was tight, but I also crammed a heater core back there as well. I used a JL 12W6 V2 and had to make the box for it smaller than desired (but all you need to do is stuff the box with some polyfill and you're good to go).
    One thing that you may want to take the time to do as well is organize that rats nest of a wiring job CC did at the factory - makes installing a sub (or anything) much MUCH easier.
    Here's some pics:
    Here's how I installed the amps too:
    Rest of it if you want any other idears - Clicky
    Neuston Boards
    Nautiques
    • skiking
      • Jun 2007
      • 118
      • TX
      Thanks for the advice Sinkoumn! Great looking boat!
      I think that is the route I am going to take. I met some of the JL audio folks at a car show and they showed me some of their new thin-line subwoofers. They are going to be great products and require much smaller enclosures. I should be able to get one on driver side and one under the clamshell without losing much space.
      Hopefully this will work, as I am planning on putting in a ballast similar to "wakefun's". :mrgreen:
