Multiple Batteries to a junction box
  • jwhposon
    • Mar 2005
    • 159
    • Oregon
    OK, lets say you have two batteries you intend to use for stereo, then maybe in the future three. Is this a good idea: I would like to take the thickest wire needed and connect two batteries together and then run one line from the positive and negative to a junction box of sorts. Then I can run my three amps from that junction box without always going back to tap into the battery. I could do this for the negative as well. Does anyone see a reasons why not to do this? I am just trying to keep a clean install as I can and not have six pairs of wires running up the gunnel.
    Jason
  • Andrew
    • Aug 2005
    • 891
    • Tuscaloosa, AL
    RE: Multiple Batteries to a junction box
    i don't see any problems with that. will save u alot of $$$ on wire and will definetly keep the install clean. i'd go ahead and run some 1/0g from the batts to the box, that way u'll never have to worry about undersized wire when u make additions in the future..........
      • 2908
      Yep, as Andrew suggests...
      1/0 between batteries and to distribution block near amps, #4 from dist block to amps. I prefer the Streetwires distribution block with screw down fuses that has terminals for four positive and four negative connections. I also like to use the pre-tinned marine power wire sold here: http://stores.ebay.com/Genuinedealz_...Q3amesstQQtZkm
      • Andrew
        • Aug 2005
        • 891
        • Tuscaloosa, AL
        check out www.knukonceptz.com i've bought quite a bit of wire, terminals, and distribution blocks from them....... GREAT PRICES! and GREAT PRODUCTS! and VERY FAST SHIPPING and GREAT CUSTOMER SERVICE.......... i could go on and on........
