Pics of problem, need advice (speakers)
  • TRDon
    • Oct 2007
    • 722
    • MN
    I was changing speakers on my 93 sport and I came across a problem where I have too large a magnet to fit against the vynal. I guess I need to know if I can cut out the 3.5" to clearance for the magnet in the side fiberglass. Will I want to reenforce it in that area or will it not be a problem to cut it there. As soon as possible would be great
  • dba4life
    • Sep 2004
    • 223
    • Raleigh, NC
    RE: Pics of problem, need advice (speakers)
    Not a solution but I wonder if that is why they moved the speaker down in my 94 Sport? Sound wise it is better where you have it. How close is it? Could you push the speaker out at all?
    • j2nh
      • Dec 2003
      • 628
      • Spread Eagle Wisconsin
      Not an expert and I did not stay at a Holiday Inn Express, but I don't see why you couldn't cut the fiberglass out and I don't see why you would have to reinforce it.
      2018 200 Team H6
      2009 196 Team ZR 409
      2005 196 Limited ZR 375
      2003 196 Limited Excalibur
      1999 196 Masters Edition
      1987 ProStar 190
      • brianc
        • Dec 2004
        • 46
        • Europe
        • 1999 196 2005 196 team zr6 2005 226 team zr6 2007 211 team zr6 2006 196 excal 2008 196 limited z409 2010 200 team ob 343
        cut them out in my boat never had a problem
        • Rick
          • Mar 2004
          • 1250
          • San Diego, Ca
          I cut them out of my boat. You could use wooden or nylon spacer rings between the vinyl and backing of the pad to space the speakers out. That would be easiest. Any auto speaker installer can get them for you. They are around $9/pair.
          Nautiqueless in San Diego
          • Andrew
            • Aug 2005
            • 891
            • Tuscaloosa, AL
            cut it.....
            • Labatt911
              • Sep 2004
              • 110
              • NE Ohio
              • None Currently : ( 1999 Pro Air 1998 Sport/Air
              I cut them out on mine and didn't reinforce. Never had a problem.
              ** Be Not Afraid **
