Deafcon III tower speakers installation
  • James
    • May 2007
    • 151
    • Indian Wells, CA
    I need help!! I am not a stereophile but I am switching out my factory Deafcon I's for Deacon III's (I like the look) and adding a Clarion 280 amp to power them. My question is... Do I have to fish an additional speaker wire through the tower to each of the Deafcon III's since I am essentially adding two more speakers? Or are the Deafcon III's already set up to work with the factory tower wiring (one speaker wire to each speaker) for the Deafcon I's. Thanks.
  • tmb
    • Mar 2004
    • 616
    • Midwest
    • '22 GS 22 ‘12 200
    James
    Take a look at the male connector. The wire should still be inside.
    '18 SAN 210 Reef Blue/Admiral Blue Metal Flake
    '12 SAN 210 TE Black/Masters Blue
    '09 SAN 210 TE Black/Fury Red
    '08 Air 216 TE
    '02 Air 216
    '98 Sport Nautique
    '89 MC Prostar 190
    • James
      • May 2007
      • 151
      • Indian Wells, CA
      There is only one wire (with of course the pos and a neg) coming out each side of the cross member of the tower for each Deafcon I. The connection is made to the red and black terminals on each speaker (you have to unscrew each terminal and slip the wire into the terminal and then tighten the terminal down). The Deacon III's have one "female plug" for each PAIR of speakers. The "male" end of the plug that attaches to the speaker wire comes apart and there are connections for TWO wires (in other words... 2 pos terminals and 2 negative terminals inside the plug) per each "male" plug. My question is: Do I have to fish another wire through each side of the tower and connect that wire to the "male" plug for each Deafcon III so effectively each of the 4 total speakers are connected to their own wire?
      • Quinner
        • 2246
        • Correct Crafts
        My system (NVS) uses a single ( +/- ) 12ga wire to each speaker module despite each module containing more than one speaker, so your single wire to each module should be fine assuming it is sized correctly.
        • AuMDLST
          • Apr 2007
          • 870
          • Orlando, FL (Butler Chain)
          When referencing the female plug are you looking at a nutrick (sp ) connector? - either way you only need the single pair of wire (one pos and one neg) the speakers are wired internally in the defcon 3 cans - although the connector has the option of 2 pos and 2 neg you will only use pos 1 and neg 1 ( they are identified as 1 and 2 respectively
          2006 SANTE 210 (Pending Sale)
          2005 206 TE (Previous)
          • Quinner
            • 2246
            • Correct Crafts
            Neutrik, that is what is used on the NVS and just as described by AUMD.
            Looks like this or check out the Neutrik Site
            • James
              • May 2007
              • 151
              • Indian Wells, CA
              Thank you all for your help. That is the plug I have.
              Anyone know the smallest gauge wire recommended?
              I my tower was wired for Deafcon I's do I need heavier gauge wire for Deafcon III's.
              I will be using the Clarion 280 amp and I never turn the volume up louder than what would prohibit normal conversation. Thanks
              • Quinner
                • 2246
                • Correct Crafts
                Most likely what is there is fine, I would try using the existing wire first, if it sounds good to you, it's good to go.
                Heavier wire could create other issues like needing larger grommets, perhaps drilling/enlarging the existing holes in the tower, etc.
                • James
                  • May 2007
                  • 151
                  • Indian Wells, CA
                  Thanks.
